Good Afternoon,
I am using the FieldChooser and i set the property ExpansionIndicatorDisplayMode="Never".
But when i export to excel the FieldChooser back to show the tables of ForeignKey.
Can someone help me?
Thank you.
Hello All,
Our development team have investigated this issue deeply and we conclude that the field chooser is not affected by exporting to excel. What happens is that exporting to excel causes the data presenter to load all the records, including child records. Loading of the child records causes the second field layout to be created as well. Therefore when the field chooser is brought up, the second child layout shows up. In general this is not related to exporting to excel and was caused by the fact that the records was recursively traversed, and this generate the second layout and make it to show in to field chooser. In order to avoid this behavior you can do the following after exporting you can try to delete the layouts that was generated.
I hope this helps.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Hello Tadeu, We reproduce this behavior and confirm that is development issue and I have logged to our system to be fixed. Currently our developers are working on this to be fixed in the next service releases. Let me know if you have any further questions.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
I'm wait for answers. Anyone get to solve this problem?
Hello , I have created case (CAS-45867-670S45) for this behavior and manage to isolate it. I will get back to you in the case for more details. Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Thank you for the sample. I was able to reproduce this behavior. In my test project I tested this with another type of data source and this is what makes the difference.
This looks like an issue and I have forwarded this to the developer support team so that they can investigate this further.
