415
Proper way to set the datacontext of a ContentPane?
I need to bind a property in my viewmodel to a property in a contentpane (IsEnabled for example).   The following doesnt work, as I get an error that SetIsEnabledInTheVM is not a dependency property:
<igDock:TabGroupPane>
  <igDock:ContentPane x:Name="contentPane">
      <ContentControl>
          <vm:MyViewModel SetIsEnabledInTheVM="{Binding ElementName=contentPane, Path=IsEnabled}" />
      </ContentControl>
  </igDock:ContentPane>
</igDock:TabGroupPane>
After some reading up, I think this should work if the VM is set as the datacontext of the ContentPane (or ContentControl?).  But even if I do set the datacontext to my vm, I still dont see my view properly.  Where should I be setting the datacontext here, and how do I then access the SetIsEnabledInTheVM property?
Thanks!
