45
Get the CellValuePresenter or Editor for a newly created cell in a new record
Hi there,
I need some help!
I'm iterating through, adding in new rows to an already rendered XamDataGrid.  While I add in these new rows, I need to get access to each cell's Cell Value Presenter or its Editor.  I know I can use the use the Cell object's Value property, but I'm using a custom editor, so I need access to the CVP or Editor to set my custom editor's value property.  The way I understand it, these elements won't be created until the XamDataGrid has a chance to initialize the new record.
If I try to retrieve the CVP when I create the DataRecord, it comes back null.  Is there an event I can tie to to get the CVP?
 foreach (string line in lineParsedText)
                object newItem = (myGrid.DataSource as IBindingList).AddNew();
                Type objType = newItem.GetType();
                DataRecord newRecord = (myGrid.Records. Last() as DataRecord);
                IEnumerator cellParsedText = line.Split(delimiters, StringSplitOptions.None).GetEnumerator();
                foreach (Cell myCell in newRecord.Cells)
                    PropertyInfo property = objType.GetProperties().FirstOrDefault(x => x.Name.Equals(myCell.Field.Name));
                    if (!cellParsedText.MoveNext())
                        break;
                    if (!property.CanWrite)
                        continue;
                    var assignmentDelegate = new EventHandler<Infragistics.Windows.DataPresenter.Events.InitializeCellValuePresenterEventArgs>(delegate(object propertyChangedSender, Infragistics.Windows.DataPresenter.Events.InitializeCellValuePresenterEventArgs propertyChangedEventArgs)
                            if (myCell != null && propertyChangedEventArgs.CellValuePresenter == CellValuePresenter.FromCell(myCell))
            CellValuePresenter cvp = CellValuePresenter.FromCell(myCell);
            if (cvp != null && cvp.Editor != null)
                ValueEditor editor = cvp.Editor;
                XamNumericEditor customEditor = editor.Template.FindName("XamNumericEditorWrapper", editor) as XamNumericEditor;
                if (customEditor != null)
                    customEditor.Text = displayText;
                    return;
                editor.Text = displayText;
                    myGrid.InitializeCellValuePresenter += assignmentDelegate;
Thanks to anyone that can help!
