695
print preview issue through XamReportPreview
Hi I am dealing with rich text box print preview. The problem is I am stuck at the way to embed the rich text box inside Report object.
Basically I wanted to use XamReportPreview.GeneratePreview(Report) method to show the to-be-printed rich text box including all the font and size attributes.The code I used is following
            RichTextBox rtb = new RichTextBox();
            // Create a FlowDocument
            FlowDocument mcFlowDoc = new FlowDocument();
            // Create a paragraph with text
            Paragraph para = new Paragraph();
            para.Inlines.Add(text);
            // Add the paragraph to blocks of paragraph
            mcFlowDoc.Blocks.Add(para);
            rtb.Document = mcFlowDoc;
            rtb.Width = 600;
            rtb.Height = 800;
at this point I created a RichTextBox object and "text" is the actual rtf passed over from somewhere else. Then,
            EmbeddedVisualReportSection section = new EmbeddedVisualReportSection(rtb);
            previewedContent.Sections.Add(section);
I embedded this rtb into a Report object called previewedContent. When I tried to preview this report, the rich text attributes cannot be interpreted. How can I convert the text into the rtf?
  • 695
    Verified Answer
    this issue has been resolved, we can use memory stream to load rtf info. see this link for more info:
    http://social.msdn.microsoft.com/Forums/en-US/wpf/thread/308c5712-028a-461e-982e-d03c0f228210/
