I have create a custom template for the ScrollViewer and since this :
- The grid only show a few row
- The scrolling does not work very well... by example the "Record tool tips" only display the first row !
Here is the template :
<Style x:Key="{x:Type ScrollViewer}" TargetType="{x:Type ScrollViewer}"> <Setter Property="OverridesDefaultStyle" Value="True"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type ScrollViewer}"> <Grid Background="Red"> <Grid.ColumnDefinitions> <ColumnDefinition/> <ColumnDefinition Width="Auto"/> </Grid.ColumnDefinitions> <Grid.RowDefinitions> <RowDefinition/> <RowDefinition Height="Auto"/> </Grid.RowDefinitions> <ScrollContentPresenter/> <ScrollBar Name="PART_VerticalScrollBar" Grid.Column="1" Value="{TemplateBinding VerticalOffset}" Maximum="{TemplateBinding ScrollableHeight}" ViewportSize="{TemplateBinding ViewportHeight}" Visibility="{TemplateBinding ComputedVerticalScrollBarVisibility}"/> <ScrollBar Name="PART_HorizontalScrollBar" Orientation="Horizontal" Grid.Row="1" Grid.Column="0" Value="{TemplateBinding HorizontalOffset}" Maximum="{TemplateBinding ScrollableWidth}" ViewportSize="{TemplateBinding ViewportWidth}" Visibility="{TemplateBinding ComputedHorizontalScrollBarVisibility}"/> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style>
I have find the problem, it is in my scrollviewer template :
I have take a look at the template used in xamDataGrid and find the solution , I have to change the scrollcontentpresenter to :
<ScrollContentPresenter CanContentScroll="True" Content="{TemplateBinding ScrollViewer.Content}"/>
