When I select the menu item 'Minimize the ribbon' from the Quick Access Toolbar the grid below the ribbon does not resize to fill the space. The space where the ribbon was is now black. How do I get the grid to resize when the ribbon is minimized?
<igRibbon:XamRibbonWindow x:Class="TaskScheduler.MainWindow" xmlns:app="clr-namespace:TaskScheduler" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igThemes="http://infragistics.com/Themes" Title="Window1" Height="471" Width="859" Loaded="Window_Loaded" xmlns:igRibbon="http://infragistics.com/Ribbon"> <igRibbon:RibbonWindowContentHost> <igRibbon:RibbonWindowContentHost.Ribbon> <igRibbon:XamRibbon Height="85" Name="xamRibbon1" Theme="Office2k7Blue"> <igRibbon:XamRibbon.ApplicationMenu> <igRibbon:ApplicationMenu /> </igRibbon:XamRibbon.ApplicationMenu> <igRibbon:XamRibbon.QuickAccessToolbar> <igRibbon:QuickAccessToolbar /> </igRibbon:XamRibbon.QuickAccessToolbar> </igRibbon:XamRibbon> </igRibbon:RibbonWindowContentHost.Ribbon> <Grid Width="Auto" Height="Auto"> <Grid.RowDefinitions> <RowDefinition Height="30"/> </Grid.RowDefinitions> <TextBox HorizontalAlignment="Left" Margin="52,10,0,-3" Name="textBox1" Width="283" /> </Grid> </igRibbon:RibbonWindowContentHost></igRibbon:XamRibbonWindow>
You set the Height of the xamRibbon to 85 but when the ribbon is minimized, it doesn't need 85 pixels so there is a section of the window where there are no wpf elements painting. In addition, you need to have at least one RibbonTabItem - even if you set its Visibility to Collapsed - although the MS UI Guidelines indicate that you must have tabs, groups and controls.
