130
Clear the Selection of grid row in XAML on certain action
I have a xamDataGrid and i want to clear the selection of the row on click of a button. I want to achieve this in XAML (may be by triggers) by binding some boolean property.
Do I need to make ActiveRecord to null and also do something like SelectedItems.Record.Clear???
Abdi
  • 2490
    Hello Abdeali,
    One way to achieve the functionality you are looking for, is to use Command.
    If in your scenario you do not use code behind I will suggest using the button which clears the selection with Command. Assuming that you want to clear all selected records, I have created a small sample application, please find it as an attached file.
    It is also necessary to set the ActiveRecod to null, for example:
                            myXamDataGrid.SelectedItems.Records.Clear();
                           myXamDataGrid ActiveRecord = null;
    If you need further assistance concerning this matter, please let me know.
    XamDataGrid_UnSelect_Command.zip
