510
Numeric Control Problem in Windows 8
In Windows 8 PC's, Nos not properly align. Some nos showing up and down.
  • 48586
    I am just checking about the progress of this issue. Let me know If you need our further assistance on this  issue?
  • 22852
    Madhan,
    There was a similar issue fixed in the February service release last year so if you are not using anything later than 2013 Volume 1 then upgrading and testing to see if it resolves the issue is a good suggestion.  Also the issue that was fixed was found to be specific to some fonts so it will also be helpful if you let us know what font you are using if this is reproducible in 2013 Volume 1 and later.  If you are looking for a workaround, setting TextRenderingMode to GDI on the editor may also work around this issue.  You can also set this for all controls by setting the static UseGDIPlusTextRendering property on the DrawUtility class to false.
    Let us know if you have any questions with this matter.
  • 48586
    Could you please let me know the exact version of Infragistics which you are using ? Have you tested your issue with the latest service release of Infragistics 14.1?
    I am waiting for your feedback.
