9364
Summing a range of cells + associating a generated formula with a column
From the Infragistics documentation, it sounds like I should be able to write a formula like sum( [Column001] : [Column120]) to add up the values in all 120 columns starting with column001. But the calculation fails at runtime if I do this. Is this kind of Excel-like range summation supported?
If not, the second question is I would be forced to use something like sum([Column001], [Column002], [Column003], ....., [Column120]).  Can I programmatically generate this string and associate the formula string to the unbound column? How do I programmatically associate a formula string with an unbound column?
Third question, is there a limit on the number of arguments to the sum() function? The Microsoft provided sum() function seems to limit it to 30 arguments but for the Infragistics sum function could handle over hundred when I tried thru designer. So is there a limit on the number of arguments?
Thanks!
Parents Reply Children
No Data
