The bottom band that has the row selector is created with the default layout in the designer and the top is created with the Infragistics Layout and Behavior presets. Is there a way of configuring this preset to have the row selector. I was thinking of adding a bogus column (read only that selects the row on cell click action) at the front and that should work but I figured there was probably a flag to set.
Simple solution, just turn on the property Row Selectors from the Feature Picker.
