I'm getting "Index was outside the bounds of the array." error when setting the datasource of an ultragrid. I read this has to do with threading, however, I'm not familiar enough with the concept to see where I'm going wrong.
What do I do to correct this?
Thank you.
Just in case somebody else got the same issue, it also can happen when you don't have the right .NET version installed. In our case, we got the exception only on a fresh install of Windows 8. The same application running on Windows 7, but using the same database as a datasource didn't fail; the only difference between the environments was the .NET versions. The ones that were missing on the Windows 8 environment were .NET 3.0 and .NET 3.5. After installing those and rebooting, we solved the issue.
The version of Infragistics controls used was 10.2
Regards
This can be closed now. Thank you.
I am just checking about the progress of this issue. Let me know If you need nay further assistance on this issue?
Thank you for your feedback.
We are waiting for your further details.
Thanks Mike. I can't seem to repo the error right now. I will post the call stack when I'm able to.
