120
UltraOptionSet Items image tooltip
Hi
I have a UltraOptionSet with 3 items, the items are having images at the end. I want to display the tool tip on the image whenever mouse hover is on Items image. Any suggestions.
appearance12.TextHAlignAsString = "Left";
this.ultraOptionSet1.Appearance = appearance12;
this.ultraOptionSet1.BorderStyle = Infragistics.Win.UIElementBorderStyle.None;
appearance8.Image = ((object)(resources.GetObject("appearance8.Image")));   //Image tooltip should be enabled here
appearance8.ImageHAlign = Infragistics.Win.HAlign.Right;
appearance8.TextHAlignAsString = "Left";
valueListItem1.Appearance = appearance8;
valueListItem1.CheckState = System.Windows.Forms.CheckState.Checked;
  • 469350
    I was able to do this using an UltraToolTipManager and some code in the MouseMove event of the OptionSet. Here's the code I used:
            UIElement lastElement = null;
            private void ultraOptionSet1_MouseMove(object sender, MouseEventArgs e)
                // Get the OptionsSet
                UltraOptionSet optionSet = (UltraOptionSet)sender;
                // Get the UIElement that the mouse is currently over.
                UIElement element = optionSet.UIElement.ElementFromPoint(new Point(e.X, e.Y));
                // If this is the same element we got the last time we were in MouseMove,
                // ignore it.
                if (element == this.lastElement)
                    return;
                // Store the last element the mouse was over so we don't show the tooltip
                // repeatedly.
                this.lastElement = element;
                // Get hte ToolTipInfo for the OptionSet control.
                UltraToolTipInfo toolTipInfo = this.ultraToolTipManager1.GetUltraToolTip(optionSet);
                // See if the element is an Image
                ImageUIElement imageElement = element as ImageUIElement;
                // If it's not an image, just clear the tooltip and bail out.
                if (imageElement == null)
                    this.ultraToolTipManager1.HideToolTip();
                    toolTipInfo.ToolTipText = string.Empty;
                    return;
                // If the element is an image, get the associated ValueListItem
                ValueListItem item = imageElement.GetContext(typeof(ValueListItem)) as ValueListItem;
                if (item != null)
                    // If we get here, we know that the mouse is over an ImageUIElement inside
                    // an item on the OptionSet. So set the ToolTipText.
                    toolTipInfo.ToolTipText = item.DisplayText;
