855
Setting for Appearance of Active Group Pane
Hi.  Is there a way to set the tab appearance of the active group pane so the tab is a different color than the rest?  It can be difficult to tell which tab is active.  Currently, when the mouse is over the tab, it has a different appearance.  I'd like to use that same appearance when ever a tab is showing the active dock pane.
Here's what it looks like now:
Here's what I want it to look like:  (looks like this with the mouse over the tab)
Thanks.
  • 71886
    Suggested Answer
    Hello gregstoops,
    I have researched your scenario and I would suggest an approach like the following:
    setting these three properties:
                ultraDockManager1.DefaultPaneSettings.ActiveTabAppearance.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(224)))), ((int)(((byte)(192)))));
                ultraDockManager1.DefaultPaneSettings.ActiveTabAppearance.BackColor2 = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(192)))), ((int)(((byte)(128)))));
                ultraDockManager1.DefaultPaneSettings.ActiveTabAppearance.BackGradientStyle = GradientStyle.Vertical;
    Please note, we are making efforts to ensure all posts are addressed by an Infragistics expert.
    We believe that the other community members could benefit from this thread as well.
    Feel free to write me if you need further assistance.
