2715
Quick acces icons
Hi!
I'm using a ribbon, an if i add to QA a button from the tabs , it displays right, but if I try to add an item from the main menu, it shows an icons that looks as its picture is missing (white rectangle with x)
Any ideea why? Or how should i disable to Add to QA in the main menu?
Thanks!
  • 20872
    Verified Answer
    This is expected behavior. The default setting of the ButtonTools is to show ImagesOnly and since there are no any assigned images yet. You could change that by setting ToolDisplayStyle on your Toolbar.
    Please let me know if you have any other questions with this matter.
