Hi!
(I've also posted this in the "Installers" section, but no one seems to be active there)
I've built an WinForms app using the Infragistics NetAdvantage in the trial version. Using theese resources, I've built a release (executalbe + ig libraries) and distributed for testing on a few PCs. Everything went fine, the app worked ok.
After buying the NetAdvantage cdkey and upgrading my application (with version utility) i've built another release (executable + ig libraries) , but this time it works only on my pc (where ig is registered) and on another pc wich didn't had NetAdvantage trial installed.
Could you give me a explanation, or some directions on how should I corectly deploy my application ?
Thanks!
Let me know if you still experience the described issue and you need help.
Stefaniya
What exactly you see when you run the application? Did you have issue loading the dll’s or issue with the license? Have you tried to set for each reference in your project CopyLocal to true or copy manually the dlls in the bin folder? If this does not help, please give me more details what happens on other machines and I will be glad to research this question for you.
