2715
How to save new records inserted in a ultragrid's child band?
hi! the following snippet loads the data from three tables in two datasets and adds a relation between them : - users (user_id, name) - roles (role_id, role_name) - user_roles(user_id, role_id); into a Infragistics ultragrid. The data is siplayed in the grid, offering the posibility to add new rows. but here come the problem...how should i build the data adapter's insert command in order to insert my newky added row into the user_roles table ?
_cmd = new OracleCommand("select * from um_users", _conn);
            _odaUsers
= new OracleDataAdapter();
            _usersDataSet
= new DataSet("um_users");
            _odaUsers
.SelectCommand = _cmd;
            _odaUsers
.Fill(_usersDataSet, "um_users");
            _cmd
= new OracleCommand("select u.user_id,
r.role_id, r.role_name, r.descr "
"from um_users u " +
"inner join um_user_roles
ur on u.user_id = ur.user_id "
"inner join um_roles r
on ur.role_id = r.role_id "
, _conn);
            _odaUsers
OracleCommand _icmd = new OracleCommand("insert
into um_users_roles(@uid,@rid) values(?,?)"
, _conn);
            _icmd
.Parameters.Add("@uid",
Oracle
.DataAccess.Client.OracleDbType.Int32, 3, "USER_ID");
            _icmd
.Parameters.Add("@rid",
Oracle
.DataAccess.Client.OracleDbType.Int32, 3, "ROLE_ID");
            _odaUsers
.InsertCommand = _icmd;
            _odaUsers
.Fill(_usersDataSet, "um_users_roles");
            _usersDataSet
.Relations.Add("users_uur",
_usersDataSet
.Tables[0].Columns["USER_ID"],
_usersDataSet
.Tables[1].Columns["user_id"]);
  • 469350
    This is a bit outside my area of expertise, since the grid does not get involved in the back end, it only deals with the local data source. I recommend checking Microsoft's documentation on the DataAdapter.
    Or, you might want to post your question in a more general DotNet programming or data binding forum, since your question isn't really related to the WinGrid.
