hi i was working arrround some old project and i found a problem.
i have two forms one is an mdi form parent and the other is an mdi form child
both forms have the same icon "Icon.ico"
in the mdi form parent i have a menu made with the infragistic tool bar
the problem is that when i try to maximize the mdi child form. the icon that apears becames another icon and is not in the prjoect
and i was looking all over the project to found the problem and nothing, i also set the icon on runtime on the event resize but stills happen
this is the image with the icon ......
as you can see on the side of the menu Conexion apears a flag icon and is not the icon i configure on the mdi child form... i hope you can help me with that
PD sorry if my english is bad ... but i am from a foreign country and my first lenguage is espanol
Sorry, I dragged and dropped.
Here are the attached images I failed to attach before. First one is a restored MDI child and the second is a maximized MDI child.
The version of the library we have is 6.1.20061.28
Hello Paul,
For some reason the images are not visible so I am not really sure what is the behavior that you are seeing in your application.What version of the Infragistics Windows Forms controls you are using in your application?
In order to attach the images could you please use "Insert Media" button, or go to "Options" and add the zipped attachement there, so I will be able to look into your issue, and research it further for you.If you have any other questions please feel free to let us know.
I have encountered a similar problem. What was the work around?
This is what I am seeing:
Best regards,
-Paul-
I have encountered the same problem, although it appears like the icon becomes over-sized when the child MDI form is maximized.
What was the work around???
I will inform you about the progress of this issue at the following support ticket: CAS-46442-MB3NVV. If you have any further question please submit them on the created ticket.
Stefaniya
