425
usercontrol in panes v6.1 problem
I was wondering if any one could help me determine if this is a known issue with  the dockmanager version 6.1.  If I try to dock 2 basic usercontrol as a tabgroup then I can't swtich between the tabs.  If I pull the panes apart and put them side by side, no problem.  Also if I make them grouped in a tab and I pull that whole tab group out so that it is floating tab group, swtiching between the tabs works.  I've tried just using a standand panel instead of a usercontrol and that worked fine.  I have this same code running in a later version and seems to be working but I really needed to be able to do this back in some older code.
Eric
  • 44743
    It sounds like there was a bug in that version which was fixed in later versions. Unfortunately, version 6.1 is no longer supported. You can try to download the latest SR for 6.1 to see if it fixes your issue. But if not, your only option is to upgrade to a later version.
