308
Column drag/drop in child band on drag and drop in band[0] in ultragrid
Hi Guys,
I have a ultrgrid that is bound to a data source at run time.
I have got 2 bands in it and that have some same columns.
I have a requirement that whenever user drags and drop the columns in band[0], the respective column in band[1] should be moved the same way simultaneously with the the column in band[0]
Please help!!!
Sanjiv
  • 469350
    Suggested Answer
    Hi Sanjiv,
    What, specifically, are you having trouble with?
    There's no build-in functionality in the grid to do this. You would have to code this yourself and update the grid's underlying DataSource when the row is dropped.
