475
Missing column separators when using AppStylist
Hi!
I'm having trouble with the appearance of the columns in an UltraListView when using an AppStylist theme file.  The problem is when applying the theme the column separator lines disappear, making it difficult to see where one column starts and ends (see screenshots below).  Is there a property in the AppStylist or in UltraListView to force the display of these separators?
Without AppStylist theme.  Column separator lines are visible.
With AppStylist theme.  Column separator lines are NOT visible.
