805
Simulating SelectedItem?
We are using UltraCombo as a multi-column combobox replacing the WF built-in version. I've muddled my way through some of the required changes, but I'm stumped by SelectedItem.
Under WF SelectedItem returns the row from the datasource, which I then cast back into the class in the array that's feeding it - in this case, an object called Fund. SelectedRow returns an UltraGridRow instead, and since there's no casting for this into our Fund object, replacing SelectedItem with SelectedRow fails - so this extremely common bit of code doesn't work:
aFund = _view.Funds.SelectedRow
Is there a way to do this with writing lots of casting methods? Maybe I use SelectedRow's index and then use that into the datasource?
Maury
