80
Updated to 2009.1 and now it doesn't work?
How comes this doesn't work now? _toolbar is my form's UltraToolBarsManager. _btnXXXXX are assigned to _toolbar.Tools("key")
            _toolbar.BeginUpdate()
            Me._btnEditar.SharedProps.Visible = False
            Me._btnGuardar.SharedProps.Visible = True
            Me._btnCancelar.SharedProps.Visible = True
            Me._btnRecargar.SharedProps.Visible = False
            _toolbar.EndUpdate()
The buttons I set to visible doesn't appear, and the ones I set visible to false doesn't dissappear... this worked fine with 2008.3 ... any change I should know?¿
  • 5389
    Suggested Answer
    asin,
    When working with a particular instance of a tool, you should be setting the InstanceProps properties rather than the SharedProps properties, since the InstanceProps properties will override the SharedProps properties for that particular instance.  I recommend changing  your code to get a reference to the particular instance of the tools you are working with (either through a specific UltraToolbar's Tools collection or a RibbonGroup's Tools collection), and then setting the tool's InstanceProps.Visible property.
    Hope this helps,
    ~Kim~
