3166
LoadFromXml difference from 2007 Vol.2 (7.2) and 2008 Vol.3 (8.3)
Is there a difference between implementation of LoadFromXml from 2007 Vol.2 (7.2) and  2008 Vol.3 (8.3)? I general I am trying to find out any improvements in loading the settings when some schema change have occured.
In my current test,
  • I saved the grid settings
  • Added a new column to the data source
  • Loaded the previous saved setting
In 2007 Vol.2
  • The new column was not visible. NOTE, NewColumnLoadStyle  was  default (Show)
  • The column was not visible in the column chooser
  • In InitializeRow, trying to access the corresponding cell resulted in key not found exception.
  • In short, the new column did not exist.
In 2008 Vol.3, all of the problems did not occur. Also rest of the settings like ColumnOrder, Sorting were correctly persisted.
I am trying to make a case to the manager that 2008 Vol.3 solves number of versioning (schema) problems.
Bhavesh
  • 37774
     It's possible that these issues were addressed by bug fixes between the version of 7.2 that you have as well as 8.3, though I am not aware of any changes in the implementation of the deserialization logic.  The 8.3 version contains any fixes that had been made throughout previous versions.
    -Matt
