1187
Format axis labels
I am using a bar chart for the first time with multiple bars per 'series'.  My data source is a datatable with 4 columns; datetime, integer, integer, integer.
 1. How can I format the X axis series labels for the date 'MM/dd'.  Only show the month and day.  I have tried several things including ".Axis.X.Labels.ItemFormatString = "<ITEM_LABEL:MM/dd>"" without success.
 2. How can keep my Y axis labels whole numbers only.  My data values are low numbers generally between 2 and 10 so the X axis wants to show fractions.   I only want to show whole numbers; 1,2,3,4,5,6,7,8,9,10.
 3. How can I customize the bar labels on the X axix?  My integer column names are 'qty1', 'qty2' and 'qty3'.  How can I set the column labels on the chart through code?  Instead of 'qty1', show 'Sales Over'.
