How do I set the Image used for PopupRibbonGroupTool (in QuickAccessToolbar)? RibbonGroup does not have SharedProps which could be used to set the AppearanceSmall.
I tried RibbonGroup.Setting.CollapsedAppearance.This displayed the Image in PopupRibbonGroupTool but it also displayed the image (small image) whenever the Group appears collapsed, which is not the desired behaviour.
That should be a safe place to do it.
Thanks Mike. I did this in the event handler for QuickAccessToolbarModified.
I am not sure if this is the right place. I was looking to set all the properties related to RibbonGroup in one place. Now I have to pass the Image to be displayed in the Tag property and set the Image property in the event handler.
While the RibbonGroup doesn't have a SharedProps, the associated PopupRibbonGroupTool does have one. I think if you set the image on its shared props it will override the image from the collapsed appearance.
