270
Image in TooltipFormattedText
AS per this link http://help.infragistics.com/Help/Doc/WinForms/2016.1/CLR4.0/html/WinToolTipManager_Creating_a_Formatted_ToolTip.html, we are trying to assign html formatted text to show tool tip for a text editor.
Here is a formatted text we have formed:
<div id='title' style='font-weight:bold;font-size:11.00pt;'>GAS FSFTG-11 - Gastite 3/4&quot;&quot; Flashshield Str<br />Male Ftg&edsp;&edsp;&edsp;&edsp;<span style='background-color:DarkBlue;color:White;font-weight:bold;'>&edsp;&edsp;Active&edsp;&edsp;</span></div><br /><div id='body' style='font-size:9.00pt;'>
<img style='margin:5px 5px;width:250px;height=250px' src='https://cdn.lightsamerica.com/images/555763.jpg'/>
</div>
So our issue is with the img tag which is trying to display an image from a url. We can see that there is limited html support for these tags in there. But I need a method to scale this image but also to keep the width height ratio of the actual image the same. I need to set a max width/max height. and set object-fit to contain. I found out that object-fit does not work here. Is there some other in built method for this?
  • 7535
    Hello ,
    Thank you for posting. There is no such inbuilt method for that but what you could do is get the image yourself in the code and resize it, then there's a method to encode the image as text instead of pointing to the URL. So you pass an image into that and it returns the image encoded into a string which you can then stick into an image tag.
    Something like this :
    string image = FormattedLinkEditor.EncodeImage(this.imageList1.Images[0]);
    For more information you can also refer this online help document:
    https://es.infragistics.com/help/winforms/wintooltipmanager-creating-a-formatted-tooltip
    Let me know if you any question.
    Sincerely,
    Divya Jain
    Associate Software Developer
