110
UltraGrid CellClickAction.CellSelect seems to interfere with MouseUp Event
I have a BaseListControl that contains an UltraGrid, and several class inheriting from it (we have several grids around the app).
The base has the row selection enabled by default - DisplayLayout.Override.CellClickAction is set to RowSelect. However, one of the inheriting classes requires CellSelect (for drag & drop functionality at cell level).
When I set:
            myGrid.DisplayLayout.Override.CellClickAction = CellClickAction.CellSelect;
In the inheriting class' InitializeComponent, the MouseUp event does not fire (unless I click on a scroll bar or on a line drawn in between cells). But when I comment out the above line of code, MouseUp fires every time.
I should mention - MouseDown always fires, whether the above line is there or not.
Any help would be much appreciated.
