225
Format date to get only hour
Hello guys,
I'm working on a project using Java with web service to communicate with the DB and C# to retrieve/update data from DB thanks to the Web service in Java.
Well, I have an UltraGrid and two of the columns are DateTime field. Currently, the two fields are displaying the date formatted like that : dd-mm-yyyy hh:mm:ss.
And I would like to display this : hh:mm:ss only.
I am a rookie on C# or .NET.
I also would like to know if there is a picker for the hours like there is one for the date ?
Heres's a screen  :
Thank you !
EDIT: I set the format to HH:mm:ss. When I run the application it shows me the time like 00:11:00 (so it's fine) but when I click on the fiel to edit it it shows me the date and not the time anymore. I do not mind to see the date, I care only about the time.
EDIT 2: It's okay for the seing only the time. Now my query is about the picker time to editing the field. There is something like that ?
