Using that app stylist I am trying to invert the set color of each menu item on Hover for the WebDataMenu.
I modified the MenuItemHorizontalRootHover css class, but changing anything font related doesn't seem to take effect. I've also tried to edit the Css by hand and that had no effect.
I would attach a screenshot but I can't seem to figure out how.
Hello Joe,
I recommend re-running the installer and clicking the "Repair" option to fix the Style Libraries included with the installation of NetAdvantage.
Is there anyway I can reinstall the original CSS files that were installed when I installed the NetAdvantage Select 2013 Vol. 1 controls? I think I messed up some of the themes and at this point I just would like to start over.
I will be happy to assist you with your questions.
When utilizing the AppStylist, I recommend looking over the KeyboardShortcuts pane on the right to view the list of UIRoles that can be used for particular elements. For example, when hovering the cursor of the Full Horizontal Menu, the Keyboard Shortcuts display UIRoles that start with the MenuItemHorizonalRoot (As shown in the attached screenshot). After looking through the UIRoles, you will notice the MenuItemHorizontalRootLink UIRole has several Fonts set; which are superseding the Font being set on the MenuItemHorizontalRootHover UIRole. I recommend removing the fonts being set in the MenuItemHorizontalRootLink UIRole to prevent it from interfering with the MenuItemHorizontalRootHover UIRole.
Regarding the attachment of files on the forums, you will see three tabs on the top of the page used to compose a message and post it to our forums. The second tab called "Options", allows you to attach files to the post.
Please let me know if you have any questions regarding this matter.
