I have a series of three columns I need to display images in a webdatagrid. the image I wish to display will be based on some business logic concluded from other values in the grid. I am trying to figure out how I go about manipulating the properties of each item in each ig:TemplateDataField on server side code. I've spent a long time googling this without much to show for it. I'm hoping that someone has an example.
Hi Alan,
This is great that you were able to resolve this for yourself. And, thank you for sharing your resolution with Infragistics Community!
...from what you have here, this looks quite efficient. I don't believe I have anything to add here.
Let me know if I can be of any further assistance.
Hey Troy,
It looks like I might have stubled upon a solution to my own problem. Look at the following snippet...Let me know if there is a more efficient way to do this...
Private Sub wdgApplicants_InitializeRow(sender As Object, e As Infragistics.Web.UI.GridControls.RowEventArgs) Handles wdgApplicants.InitializeRow Dim imgInfo As HyperLink Dim g As Infragistics.Web.UI.GridControls.GridField Dim strAddressLine As String Dim strCandidateName As String Dim intApplTrackId As Integer imgInfo = CType(e.Row.Items.FindItemByKey("tImageInfo").FindControl("imgInfo"), HyperLink) strAddressLine = CType(e.Row.Items.FindItemByKey("Address_Line1").Value, String) strCandidateName = CType(e.Row.Items.FindItemByKey("Candidate_Name").Value, String) intApplTrackId = CType(e.Row.Items.FindItemByKey("Appl_Track_Id").Value, Integer) If strAddressLine <> String.Empty Then imgInfo.ToolTip = "Review Application for " + strCandidateName imgInfo.ImageUrl = "~/images/icon_information16.gif" imgInfo.NavigateUrl = "~/ReviewApp.aspx?I=" + intApplTrackId.ToString imgInfo.Target = "_new" End If End Sub
This is to let you know that I have received your inquiry and will be looking into this for you. Thanks!
