1175
Sorting on TemplateFields
Hello there,
the user should be able to sort some columns, this can be normal text (names), numbers or dates.
I found this example on your page: http://help.infragistics.com/Help/NetAdvantage/ASPNET/2012.1/CLR4.0/html/WebDataGrid_Sorting.html
The example just binds directly to the data, in my case, I have Templates as columns:
<ig:TemplateDataField Key="Name" Width="260px">
<HeaderTemplate>
<asp:Label ID="lblNameHeader" runat="server">Name</asp:Label><br>
</HeaderTemplate>
<ItemTemplate>
<asp:LinkButton ID="linkBtnName" runat="server" CausesValidation="False" CommandName="Link"
Width="200px" Font-Underline="true" Style="white-space: pre-wrap;">linkBtnName</asp:LinkButton>
</ItemTemplate>
<FooterTemplate>
<div class="rowSelectEdit">
<stgwc:TextEdit runat="server" ID="txtIndvId" Width="0px" />
<asp:Label runat="server" ID="lblNameEdit" CssClass="lblRequiredField" Style="white-space: pre-wrap;">
</asp:Label>
<stgwc:ImageLinkButton ID="ibutChange" runat="server" CssClass="icoButton" ToolTip="Opens a search page where you can find your roles entry."
CausesValidation="False" ImageUrl="Images/base/Icons/16x16/media_play_green.png"
CommandName="SearchIndOrgInsert">
</stgwc:ImageLinkButton>
</div>
</FooterTemplate>
</ig:TemplateDataField>
In the Code behind, I set the sorting like this:
private void InitializeSortButtons()
            dgrRoles.Behaviors.CreateBehavior<Infragistics.Web.UI.GridControls.
Sorting>();
            dgrRoles.Behaviors.Sorting.SortingMode =
SortingMode.Single;
            dgrRoles.Behaviors.Sorting.SortedColumns.Add(dgrRoles.Columns[COL_NAME], Infragistics.Web.UI.
SortDirection.Ascending);
SortDirection.Descending);
const string COL_NAME = "Name";
But I get an error on the preRender:
"An unexpected error occured. Cannot find column Name."
Am I missing something? Is it possible to sort with the template fields?
BTW: Is there a possibility to format code better?
Thanks for your response!
