With large datasets paging seems to crash and doesnt expand child bands. Can someone give me an example of how I can prevent this from happening. DO I need to rebind grid on every postback. How can i call rowIslandsPopulating on demand?
Hi dev_here,
There seems to be a separate thread regarding this matter, please refer to it:
http://community.infragistics.com/forums/p/71083/360710.aspx#360710
Petar,
Can you give me an example of a manual on demand WHDG inside an updatepanel?
As i am still facing issues in navigation of child bands. cannot seem to be able to page/filter
Well, in my case the grid is not placed in side an updatepanel and I did not find any other way to make it work
Hello dev_here,
Thank you for sharing your solution.
EnableDataViewState may make a difference depending on whether the grid is being rebound on each postback and disabling AJAX may also make a difference if the grid is placed inside an UpdatePanel:
http://help.infragistics.com/NetAdvantage/ASPNET/2012.1/CLR4.0/?page=Infragistics4.Web.v12.1~Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid~EnableDataViewState.html
Please do not hesiate to contact me if you have any additional questions.
Finally found the way to get around this:
EnableDataViewState
="True" EnableAjax="False"
Thsi helps in getting data from large datasets with paging.
