245
WebMaskEditor and RegularExpressionValidator Problem
I have an issue with the WebMaskEditor control.  If I use this code on my ASPX page:
Zip:<ig:WebMaskEditor ID="mskZip" runat="server" CssClass="TextBox" InputMask="00000-0000" Width="90px" />
<asp:RegularExpressionValidator ID="zipValidator"  runat="server"                                  ErrorMessage="Invalid Zip Code"                                 ValidationExpression="(^(?!0{5})(\d{5})(-?)(?!0{4})((\d{4})||(_{4}))?$)"                                  ControlToValidate="mskZip">*</asp:RegularExpressionValidator>
I cannot get the validator and the WebMaskEditor to play well together. The issue that I am having is the validation control will mark the mskZip value as invalid when the value is "55555-".
The regular expression I am using should allow "5555-". As a matter of fact, it works great if I replace the WebMaskEditor with a regular ASP textbox. So I guess the issue I am really having
is that the RegularExpressionValidator doesn't work the same with the WebMaskEditor control as it does with an ASP textbox. I thought the issue might be that the validation control was seeing
the underscores in the WebMaskEditor control so I modified the regular expression to account for those. Testing it yielded the same results. Again, if I replace the WebMaskEditor with a
textbox it works as I would expect.
Here is what the code looks like whenever I replace the WebMaskEditor with a textbox:
Zip:<asp:TextBox ID="mskZip" runat="server" CssClass="TextBox" Width="90px" /> <asp:RegularExpressionValidator ID="zipValidator"                                  runat="server"                                  ErrorMessage="Invalid Zip Code"                                 ValidationExpression="(^(?!0{5})(\d{5})(-?)(?!0{4})((\d{4})||(_{4}))?$)"                                  ControlToValidate="mskZip">*</asp:RegularExpressionValidator>
Any idea how I can work around this issue?
Kevin
