355
Problem with CellSelectionChanged event VB
I'm having a problem with the results of the cellselectionchanged event when working with a grid the has column filters applied.  Examples use this site:  http://test.medicalmethods.net/jobboard.aspx
If I click "Add+" (Add to Cart) in row 1 of the unfiltered grid the job I clicked appears in the job cart.  Click "Remove" and return to the job board.  Select "SNF" in the settings grid and click "Get Jobs". Click "Add+" in row 1 again (it will be a different job).  You will be sent to the job cart with the same job as the first time. If you use row 2 in each case you'll get row 2 of the unfiltered grid each time.
I'm more of a client-server programmer than a web guy so I may be going about this wrong. I know there may be a javascript solution but I want to stick with the VB because I'm more comfortable with it.
The grid:
                                            <ig:WebDataGrid ID="grdJobs" runat="server" DataSourceID="dataJobs" EnableDataViewState="True"
                                                OnSorting="gridSorting" StyleSetName="MedicalMethods"
                                            EnableAjax="False" Width="100%"
                                                AutoGenerateColumns="False">
                                                <Behaviors>
                                                    <ig:Selection>
                                                        <AutoPostBackFlags CellSelectionChanged="True" />
                                                    </ig:Selection>
                                                    <ig:Activation>
                                                    </ig:Activation>
                                                    <ig:Paging PagerAppearance="Both" PagerMode="NumericFirstLast" QuickPages="3" PageSize="25"
                                                        FirstPageText="First" LastPageText="Last">
                                                    </ig:Paging>
                                                    <ig:Sorting>
                                                    </ig:Sorting>
                                                    <ig:Filtering Visibility="Hidden">
                                                    </ig:Filtering>
                                                </Behaviors>
                                                <Columns>
                                                    <ig:TemplateDataField Key="AddToCart" CssClass="jobboard-link" Hidden="false" Width="8%">
                                                        <ItemTemplate>
                                                            Add[+]
                                                        </ItemTemplate>
                                                        <Header Text="Add to cart" />
                                                    </ig:TemplateDataField>
                                                    <ig:BoundDataField DataFieldName="Profession" Key="Profession" Width="12%">
                                                        <Header Text="Profession" />
                                                    </ig:BoundDataField>
                                                    <ig:BoundDataField DataFieldName="Skill" Key="Skill" Width="12%">
                                                        <Header Text="Skill" />
                                                    <ig:BoundDataField DataFieldName="Setting" Key="Setting" Width="10%">
                                                        <Header Text="Setting" />
                                                    <ig:BoundDataField DataFieldName="Shift" Key="Shift" Width="10%">
                                                        <Header Text="Shift" />
                                                    <ig:BoundDataField DataFieldName="Schedule" Key="Schedule" Width="10%">
                                                        <Header Text="Schedule" />
                                                    <ig:BoundDataField DataFieldName="JobOpeningType" Hidden="true" Key="JobOpeningType"
                                                        Width="10%">
                                                        <Header Text="Job Type" />
                                                    <ig:BoundDataField DataFieldName="City" Key="City" Width="10%">
                                                        <Header Text="City" />
                                                    <ig:BoundDataField DataFieldName="StateAbbrev" Key="StateAbbrev" Width="8%">
                                                        <Header Text="State" />
                                                    <ig:BoundDataField DataFieldName="Pay" Hidden="true" CssClass="hide" Key="Pay" DataFormatString="{0:c}"
                                                        DataType="decimal">
                                                        <Header Text="Pay" />
                                                    <ig:BoundDataField DataFieldName="intJobId" Hidden="false" Key="intJobId">
                                                        <Header Text="Job ID" />
                                                    <ig:TemplateDataField Key="JobDetails" CssClass="jobboard-link" Width="10%">
                                                        <ItemTemplate>
                                                            <a href="jobdetails.aspx?id=<%#Eval("intJobId") %>">Details </a>
                                                        </ItemTemplate>
                                                        <Header Text="" />
                                                </Columns>
                                                <AjaxIndicator ImageUrl="~/images/ajax-loader.gif" Enabled="True" Location="AboveCenter" />
                                            </ig:WebDataGrid>
The VB
    Private Sub grdJobs_CellSelectionChanged(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.SelectedCellEventArgs) Handles grdJobs.CellSelectionChanged
        Try
            Dim Job1 As New Job
            Job1.JobID = e.CurrentSelectedCells(0).Row.Items(COL_JOBID).Value & "-" & Now.Ticks.ToString
            Job1.Profession = e.CurrentSelectedCells(0).Row.Items(COL_PROFFESSION).Value
            Job1.setting = e.CurrentSelectedCells(0).Row.Items(COL_SETTING).Value
            Job1.Skill = e.CurrentSelectedCells(0).Row.Items(COL_SKILL).Value
            Job1.Shift = e.CurrentSelectedCells(0).Row.Items(COL_SHIFT).Value
            Job1.schedule = e.CurrentSelectedCells(0).Row.Items(COL_SCHEDULE).Value
            Job1.jobType = e.CurrentSelectedCells(0).Row.Items(COL_JOBOPENINGTYPE).Value
            Job1.City = e.CurrentSelectedCells(0).Row.Items(COL_CITY).Value
            Job1.State = e.CurrentSelectedCells(0).Row.Items(COL_STATE).Value
            Job1.strJobID = e.CurrentSelectedCells(0).Row.Items(COL_JOBID).Value.ToString
            Dim CartItem As New CartItem
            CartItem.Job = Job1
            Me.AddToCart(CartItem)
            Response.Redirect("jobcart.aspx")
        Catch ex As Exception
            'Utilities.SendMail(JobBoardConfig.MoreInfoEmail, JobBoardConfig.ErrorLogEmail, "ORTN website", "Error in CellSelectionChanged. Row: " & row.ToString & " col: " & col.ToString)
        End Try
    End Sub
Thank you in advance for any help.
