95
Using Directoy information for the Hierarchal Data Source
I want to create a menu listing of the files in a specific directory, is that possible?  Can you point me in the right direction?
  • 3726
    Suggested Answer
    It is possible. You can save the directory structure in an C# object and then use the ObjectDataSource and bind to it. You can also take a look on how to use hierarchical data source with WebDataMenu below.
    http://samples.infragistics.com -> ASP.NET -> WebDataMenu -> Hierarchical Data
    Check the sample code here:
    http://samples.infragistics.com/2010.3/WebFeatureBrowser/srcview.aspx?path=WebDataMenu/WebMenuHierarchical.src&file=WebMenuHierarchical.aspx&font=3
    Hope it helps.
    Lubomir
