865
a script on this page is causing internet explorer to run slowly
I have a WebDialogWindow on my form and inside this dialog I have an updatepanel and two combo box.
Combobox two puplates by combo box one. For the first time is fine, but when i select another item, i get the error message "a script on this page is causing internet explorer to run slowly.......".
If I remove the WebDialogWindow, everything is fine. However, I should say that I was not getting this message before. suddenly, it started to play up.
Is there any solution?
Kamal
Parents
No Data
Reply
  • 28464
    Hello Kamal,
    It really depends on your setup, but I can suggest the following two forum threads where the very same problem has been resolved (with different approaches)
    http://forums.infragistics.com/forums/t/12799.aspx
    http://forums.infragistics.com/forums/p/6022/26157.aspx
    You can also try the latest hotfix where this issue could be addressed or the impact of script slowness inside UpdatePanel is alleviated.
Children
No Data
