20
Data retaining issue
Hi,.I'm using ig 17.1 webdata grid,which is having an editable textbox.
We will input values to the column and perform a sort it works perfectly.
Then I clear the value of the same and perform sort again,which will result in a dbnull error as the column is expecting a nulable decimal.
However I tried to override this error and perform a sort operation,
Which also worked perfectly.
But, after that while I try to sort again it retains old value.how go avoid this?
Steps to follow.
webdatagrid column having an editable textbox of type system.decimal
Enter a value say 5
Sort the column
Now clear the value
Sort again
Now sort again without inputting anything
It retains the old value is,5
  • 845
    Hello John,
    Thank you for contacting Infragistics Developer Support.
    Can you provide some additional information about how are you editing/sorting the grid?
    Is it all server-side or a mix between server-side and client-side?
    If you can provide an isolated sample reproducing the problem it will speed up the resolution of your problem immensely.
    I'm waiting for your reply.
