85
SetCellData will not accept TRUE for checkbox value
I have recorded the step for checking a checkbox in a table. It looks like this:
SwfWindow("Analysis Test Application").SwfTable("analysisSetupGridView").SetCellData 0,"Tabulate?",True
However, when playing this back, I get the following error:
SetCellData :Specified cast is not valid..
 Row = 0, Column = Tabulate?, Value = True
I have tried using True, "True", 1, -1, "1" and "-1" and I keep getting an error. Oddly enough, if I try to check a checkbox that is already checked, the statement does not produce an error. Can somebody shed some light on this?
Mike
Parents
  • 7695
    Hi Mike,
       My thought would be that your Checkbox column may not have a boolean datatype. The way SetCellData works is that it sets the underlying columns value to the value supplied. Sometimes the column can display an editor that would imply a specific data type, such as checkbox is boolean, but actually be something else entirely. To confirm this what I would recommend is to manually set a cells checkstate to checked, then call GetCellData. This should likely give you an idea of what the value needs to be.
Reply Children
No Data
