Hello ,
we have been automating .Net application using QTP 10. but some of the infragistics controls are not
getting recognized by the QTP. some of the objects with NetAdvantageTM 2005 Vol. 3 CLR 2.0 version
embeded into the application. We knew that Test Advantage of yours will solve our problem,
Still, I would like to know few details from you,
a) Do you have supported Test Advantage for NetAdvantageTM 2005 Vol. 3 CLR 2.0.?
b) If Yes, Can we get trail and licensed version to verify it on the application and Will this support QTP 10 version.
Your feedback will help us to go further.
Regards
Chary Chelloji
Thanks Ammar for the reply.
I have taken trail version (Test Advantage 2005 Vol3, CLR 2.0) from your sales department and verified it using QTP 10. I have attached requested file. Kindly let me know, whether attached file is accessible to you or not.
Hi Chary,
The only possible reason for this is having the wrong TestAdvantage version. according to the screenshot that I got from our Sales rep, the application you are testing is built with NetAdvantage 2005 Vol 3 CLR2.0 This means that you need TestAdvantage 2005 vol 3 CLR2.0. Is that the version you have? if not please install the right version then using the version utility from the Start Menu make sure the correct version is selected and try again.
If you already have the right version then the issue might be a configuration issue. Please send me the SwfConfig.xml file located in "C:\Program Files\HP\QuickTest Professional\dat" this file contains the mapping information required for TestAdvantage and I've seen issues where this file got corrupted.
Ammar
Hello Ammar,
we have been using concurrent licences for QTP 10. Licence Server is hosted at remote place. QTP 10 has installed on my machine where Test Advantage is installed as per instructions specified above.
Is this correct installation of Test Advantage?
I found Test Advantage trail version and installed it in my machines as per the instructions specified at http://community.infragistics.com/forums/p/15955/159446.aspx#159446 link.
After successful installation of Test Advantage, I have opened QTP 10 and started recording steps on the Infragistics controls. but corresponding test steps are not getting recorded in the QTP.
Kindly suggest me, if any things need to be done for issue.
Note:
Before installing Test Advantage, QTP was able to record actions on the infragistics controls atleast using x,y coordinates.
As you specified above, I have emailed to sales team at (sales@infrgistics.com) for some more infromation. But I haven't recieved any response from them to move further.
Based on the feedback from sales team, we shall decide next steps. Did I connected to intended recipient thorugh my last email. Otherwise, Please direct me to right place.
