142
Problem with Java Sample Code Or Installation Problem
I'm using RFT 8.0.0.2 and TestAdvantage 2008.3 with hotfixes.
When I attempt to try out the Sample Test Scripts that came with TestAdvantage, I get the following errors:
Description Resource Path Location Type
com.infragistics cannot be resolved to a type DataPoolSampleHelper.java TestAdvantageSampleScripts/resources line 37 Java Problem
com.infragistics cannot be resolved to a type DataPoolSampleHelper.java TestAdvantageSampleScripts/resources line 39 Java Problem
com.infragistics cannot be resolved to a type DataPoolSampleHelper.java TestAdvantageSampleScripts/resources line 50 Java Problem
com.infragistics cannot be resolved to a type DataPoolSampleHelper.java TestAdvantageSampleScripts/resources line 52 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 37 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 39 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 50 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 52 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 64 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 66 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 77 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 79 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 91 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 93 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 104 Java Problem
com.infragistics cannot be resolved to a type ExplorerBarHelper.java TestAdvantageSampleScripts/resources line 106 Java Problem
com.infragistics cannot be resolved to a type ListView_Demo1Helper.java TestAdvantageSampleScripts/resources line 37 Java Problem
com.infragistics cannot be resolved to a type ListView_Demo1Helper.java TestAdvantageSampleScripts/resources line 39 Java Problem
com.infragistics cannot be resolved to a type ListView_Demo1Helper.java TestAdvantageSampleScripts/resources line 50 Java Problem
com.infragistics cannot be resolved to a type ListView_Demo1Helper.java TestAdvantageSampleScripts/resources line 52 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 37 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 39 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 50 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 52 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 61 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 63 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 71 Java Problem
com.infragistics cannot be resolved to a type RibbonHelper.java TestAdvantageSampleScripts/resources line 73 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 31 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 32 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 33 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 34 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 35 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 36 Java Problem
The method _frmMain_Toolbars_Dock_Area_To() from the type RibbonHelper refers to the missing type UltraToolbarsDockAreaTestObject Ribbon.java TestAdvantageSampleScripts line 37 Java Problem
The method _frmMain_Toolbars_Dock_Area_To2() from the type RibbonHelper refers to the missing type ToolUIElementTestObject Ribbon.java TestAdvantageSampleScripts line 38 Java Problem
The method ultraExplorerBar1tree() from the type ExplorerBarHelper refers to the missing type UltraExplorerBarTestObject ExplorerBar.java TestAdvantageSampleScripts line 31 Java Problem
The method ultraExplorerBar1tree() from the type ExplorerBarHelper refers to the missing type UltraExplorerBarTestObject ExplorerBar.java TestAdvantageSampleScripts line 38 Java Problem
The method ultraExplorerBar1tree() from the type ExplorerBarHelper refers to the missing type UltraExplorerBarTestObject ExplorerBar.java TestAdvantageSampleScripts line 41 Java Problem
The method ultraExplorerBar1tree() from the type ExplorerBarHelper refers to the missing type UltraExplorerBarTestObject ExplorerBar.java TestAdvantageSampleScripts line 42 Java Problem
The method ultraListViewtree() from the type DataPoolSampleHelper refers to the missing type UltraListViewTestObject DataPoolSample.java TestAdvantageSampleScripts line 31 Java Problem
The method ultraListViewtree() from the type DataPoolSampleHelper refers to the missing type UltraListViewTestObject DataPoolSample.java TestAdvantageSampleScripts line 32 Java Problem
The method ultraListViewtree() from the type ListView_Demo1Helper refers to the missing type UltraListViewTestObject ListView_Demo1.java TestAdvantageSampleScripts line 31 Java Problem
The method ultraListViewtree() from the type ListView_Demo1Helper refers to the missing type UltraListViewTestObject ListView_Demo1.java TestAdvantageSampleScripts line 32 Java Problem
The method ultraListViewtree() from the type ListView_Demo1Helper refers to the missing type UltraListViewTestObject ListView_Demo1.java TestAdvantageSampleScripts line 33 Java Problem
The method ultraListViewtree() from the type ListView_Demo1Helper refers to the missing type UltraListViewTestObject ListView_Demo1.java TestAdvantageSampleScripts line 49 Java Problem
The method ultraListViewtree() from the type ListView_Demo1Helper refers to the missing type UltraListViewTestObject ListView_Demo1.java TestAdvantageSampleScripts line 63 Java Problem
The method ultraListViewtree2() from the type ExplorerBarHelper refers to the missing type UltraListViewTestObject ExplorerBar.java TestAdvantageSampleScripts line 37 Java Problem
The method ultraListViewtree3() from the type ExplorerBarHelper refers to the missing type UltraListViewTestObject ExplorerBar.java TestAdvantageSampleScripts line 34 Java Problem
The method ultraListViewtree3() from the type ExplorerBarHelper refers to the missing type UltraListViewTestObject ExplorerBar.java TestAdvantageSampleScripts line 39 Java Problem
The method ultraListViewtree3() from the type ExplorerBarHelper refers to the missing type UltraListViewTestObject ExplorerBar.java TestAdvantageSampleScripts line 40 Java Problem
Thus, I can't execute...
I thought I followed the installation instructions: double-click on "TestAdvantage_WinForms_IBM_20083.exe", accept licsense, and press next until install, and the finish when done.
After which checked the version utility to show 8.3 CLR20 was selected.
Did I miss something? Is there more?
