I have a huge problem to deal urgently with the reporting.
When I set the PaperSize property of my report to A4, the paper 215.6 x 279.4 in fact instead of 210x297.
Thus when printing by the service, couriers are distorted .
I need to send my letters of reminders before Monday morning in the correct format. How?
Best regards,
TL
Hello Thomas,
Thank you for the feedback. I am glad you have found a solution to your issue.
Thanks for reply.
I'm not in a XamReportViewer, I generates a pdf document by code.
I solved the problem by defining the pagesize on each section of my report instead of doing it on the report himself.
Thank you for your post!
I have been looking into it. Would you please try the following settings – when you start the application, press the little icon, surrounded with a red border ( I have attached a screenshot for you). Then change the Margins on the popup window shown on the screenshot. This is part from the XamReportviewer.
I am attaching the sample application I have been testing with. Please find the attachments and let me know if these steps help you.
