I want to create pie chart in windows phone 8 application in visual studio 2013. Kindly guide me step by step how to use this third party tool and please tell me each step I have installed this controls but I dont know how to use this.
Hello Aamir,
Sincerely,
Krasimir, MCPD
Developer Support Supervisor - XAML
www.infragistics.com/support
Thank you for your reply. The sample that I have attached is building and running correctly on my side. I have tested the sample on a device with Windows Phone 8 a and the sample application is running. I am attaching a screenshot made by the phone when the application is running.
I assume that it is possible the first two errors to be caused by the last error that that you are getting. Would you please test the sample on different device or an emulator and also, would you please let me know if you can run the sample without the XamPieChart?
Hi Krasimir,
When I run the application which is created by you, there are some errors occured. Please tell me how to resolve these issues
Error 1 The name "ItemLegend" does not exist in the namespace "clr-namespace:Infragistics.Controls.Charts;assembly=InfragisticsWP8.Controls.Charts.XamDataChart.v14.1". D:\my stuff\windows phone apps\PhoneApp1\PhoneApp1\PhoneApp1\MainPage.xaml line 24 Column 9 PhoneApp1
Error 2 The name "XamPieChart" does not exist in the namespace "clr-namespace:Infragistics.Controls.Charts;assembly=InfragisticsWP8.Controls.Charts.XamDataChart.v14.1". D:\my stuff\windows phone apps\PhoneApp1\PhoneApp1\PhoneApp1\MainPage.xaml Line 31 Column 9 PhoneApp1
Error 3 Unable to install application. The maximum number of developer applications on this phone has been reached. Please uninstall a developer application and try again.
Thank you for your reply. I have created a sample application for you, that shows how you can use the XamPieChart in a Windows Phone 8 application.
Please let me know if you need any further assistance on the matter.
Hi Valerie,
I didn't get your point kindly guide me each step should I follow.... I will be thankful to you
