I could not see the Forecolor property for the Infragistics Label for the report in vs.
Hi M,
Let me know if you have any questions on this.
You should see the properties for the Label control in the Properties window while in the Report designer. If you don't see the properties window, go to View -> Properties Window. With the properties window open and the Label selected you should see a property called Foreground. This is where you can change the foreground color of a label.
