I am using this function to popup a confirmation when someone makes a change in a webcombo box.
function wcPerCitizenship_BeforeSelectChange(webComboId) { var mywebcombo = igcmbo_getComboById(webComboId) if (!confirm("Are you sure you want to change this?")) return true; }Problem is it runs everytime. Twice...So if something is in a combo box, and a user clicks the drop down to change the value, it prompts then prompts again.Same thing happens if nothing is in the box.How do I make it only work once?
I changed the event to afterSelectChange
it works fine now.
