I noticed some strange behavior from a check box column wihtin a bound XamGrid recently and I can't seem to figure out a viable workaround. When I check/uncheck the check box and leave the record (either by moving to a different record or moving outside of the grid) all checkboxes in all records appear unchecked. If I reload the data source, they show correctly. I'm not sure why this is happening or how to prevent it. Oddly enough, I tried using a templated column with a bound check box and saw the same behavior. Has anyone run into anything like this before?
Thank you for your feedback. I am glad that you have resolved your issue. If you need any further assistance feel free to write.
Thanks again.
Okay, never mind. Turns out that something in the control template for the combo box control in my custom styles was messing this up.
