In ultrawebgird copy the selected row to new row (which is blank). I have applied group by.
Hi DayanaArul,
I am following up to check if you are still experiencing any issues. Please contact me if you require further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
As far as I can understand you want to be able to copy some row to a new row, i.e add a new row with the data of an existing one.
Given that you have grouped the data on your grid you should be able to add a new row by using something like :
if (UltraWebGrid1.DisplayLayout.SelectedRows.Count > 0) { UltraGridRow row = new UltraGridRow(); row.CopyFrom(UltraWebGrid1.DisplayLayout.SelectedRows[0]); UltraWebGrid1.DisplayLayout.Rows.FromKey(row.Key).Rows.Add(row); }
Keep in mind that the above code adds a new row to your grid, not your data source. Note the nested structure of the rows when the grid is grouped by a column.
You may be interested in the following discussion regarding grouping in UltraWebGrid:
http://news.infragistics.com/forums/p/12442/64791.aspx#64791
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
