We've noticed that even those cells that are set as "IsReadOnly" in a xamGrid are still selectable. If I edit a cell and then hit the tab key, I want the next editable cell to be active. So I've added some ActiveCellChanged code that finds the next editable cell in the row and sets the IsActive property to true. This seems to work pretty slick except... If I edit one cell, hit tab (IsActive is set for the next editable cell) and then edit this next cell, once I leave the grid I get an error stating that "The entity is currently read-only". I'm not sure why. If I use the mouse to select the next editable cell, the update works fine.
Outlook has removed it again. I have created a case for you. When you receave an email notification, attach the sample to the case - make sure the file is zipped. I think it's better this way.
Thank you,Sam
I've sent a new one. It's not easy to get the project that small since the edmx is so large (even with very little in it) but I've trimmed as much fat as I can.
The attachment seems to get removed. I think the Outlook take up to 3MB. Is there a way to reduce the size to 3MB?
Okay. Thanks. Sent...
Brian,
Please send your sample to support@infragistics.com and in the subject line specify 'Sam'. I will pick it up, test it and will follow up with you.
