2335
Excel Object Performance Issue with 300+ formula cells in 3 sheets
We are using Infragistics Excel for Silverlight and have 3 sheets with average of 100+ formulas in a sheet and cells from one sheet use other sheet cells/formals. and it is taking too long to calculate and return results. We have tested the functionality with and it works fine with any two sheets.
we have also tried to test it by moving all data to single sheets but it does not perform well and have performance issues. We also exported final sheets in excel to check if there is any delay or problem but it works fine in excel.
Can you please suggest us any work around or tips to overcome this performance issue?
