125
Suddenly cannot edit cell in Webgrid in Firefox 3.6
Up until an upgrade to Firefox 3.6 this has always worked fine, but now cannot edit cells in webgrid across multiple sites on our webserver.
I have found a couple posts on this but no definitive solution. We're using ASP.NET Infra 2008 ver 2 for clr 3.x.
All sites share the same ig_common scripts directory so the ig_WebGrid.js file only exists in one place. I have tried the 3 different posts I found, replacing the igtbl_getAbsBounds function with varioius versions of recommendations but none worked for me.
Since this is obviously a very common issue, isn't there a hotfix version of ig_WebGrid.js available for download somewhere? If not, is there some solution available from the Infragistics team?
Thank you for any help and direction.
