769
urgent: How to use OnSelectedIndexChanged for Dropdownlist?
Hello everyone,
 I have an ultrawegrid that I have two dropdownlists. Both dropdownlists are templatedcolumns (that means I'm using a Standard ASP.NET 2.0 dropdownlist control).  For both dropdownlist I use the OnLoad method to load my dropdownlist with items.  In the dropdownlist control I specified the OnSelectedIndexChanged and so everytime I click an item from the dropdownlist it suppose to fire an event from the OnSelectedIndexChanged but it doesn't. I tested with another dropdownlist on the same page but not embeded into the webgrid and it does fire the OnSelectedIndexChanged event.  Can anyone tell me why I can't fire the OnSelectedIndexChanged when I use it as a templatedcolumn?
 Also, is it right for me to use the OnLoad event method to initialize my dropdownlist items??
Here is a snippet of my code:
<CellTemplate>
<asp:DropDownList ID="DropDownList1" runat="server" OnSelectedIndexChanged="DropDownList1_SelectedIndexChanged" AutoPostBack="True">
<asp:ListItems Text="(Select)" Value="" Enabled="True" Selected="True"/>
</asp:DropDownList>
</CellTemplate>
public void DropDownList1_SelectedIndexChanged(object sender, EventArgs e){
 //Do something...
 If you know a way or a solution, please let me know asap.
 Thanks very much in advance!
HS2
